Avoiding repeating commands
vrod5454
Post by vrod5454 » Dec 17th, ’19, 22:22
I have a SEND text expander that gives options to pick from. I would like to then insert a snippet after the user makes their selection. Is there a way to do this so I don't have to repeat the command after every option.
Currently I have this:
Option 1 ::Lorem ipsum dolor sit amet, consectetur adipiscing elit. %INSERT_.fn_Mark_Important%
/Option 2::Integer hendrerit, quam vel commodo tempor, lacus massa porttitor nibh. %INSERT_.fn_Mark_Important%
/Option 3::Fusce nec tortor in diam viverra commodo. %INSERT_.fn_Mark_Important%
/Option 4:: Pellentesque facilisis volutpat nulla. %INSERT_.fn_Mark_Important%
I'm looking for something like:
Thanks for your help.
Post by Marko » Dec 19th, ’19, 20:47
%INSERT_Selections%
vrod5454
Post by vrod5454 » Dec 20th, ’19, 21:52
Got it. Thanks.
