Trigger inside a word or after some other keys
pbengert
Post by pbengert » Dec 6th, ’19, 07:18
I'm using a programm in which I oft get a newline with some other combination like ALT+D oder ALT+B.
In these lines autocomplete does offer a selection directly at the beginning unless I type a SPACE first as ALT+B is not recognized as a new line.
Is there any way to trigger it from there, like "inside" a word. As ALT+D oder ALT+B can change I can not easily preprend that combination to the "trigger string".
I'm using auto-complete.
Any ideas?
Thank you,
Peter
Post by Marko » Dec 6th, ’19, 18:50
Hi Peter, I’m not sure I understand what you mean. Auto complete word recognition is cancelled by pressing Enter, Space, Escape, comma and many other keys.
