Oblomov
Post
by Oblomov » Dec 3rd, ’19, 10:40
I'm trying to add a shortcut "Ctrl + Shift + Win + Alt + 7"
However, despite being able to do so, upon applying I get
Could I be doing something wrong perhaps? As it seems, there is no duplicate to speak of as such
Post
by Marko » Dec 3rd, ’19, 14:36
What does the error report say?
Oblomov
Post
by Oblomov » Dec 3rd, ’19, 16:23
Marko wrote: ↑Dec 3rd, ’19, 14:36
Post
by Marko » Dec 4th, ’19, 18:27
As suggested by error report, there must be a duplicate - please check again.
Oblomov
Post
by Oblomov » Dec 4th, ’19, 19:14
Marko wrote: ↑Dec 4th, ’19, 18:27
Definitely isn't anywhere I can find... tried checking manually several times
Perhaps there is some sort of file I can look into?
Post
by Marko » Dec 4th, ’19, 19:54
I could only check if I see the file - you can send it to our support mail.
