CTRL SHIFT C ¦ CTRL SHIFT V
Studi1
Post by Studi1 » Nov 20th, ’19, 17:29
How can I circumvent my problem in MS Word with the commands 'CTRL SHIFT C' + 'CTRL SHIFT V'?
- I use them regularly.
- Since I installed FastKeys, they don't work any longer.
Post by Marko » Nov 20th, ’19, 21:28
Change the Clipboard Manager shortcut in Preferences/Functions/Clipboard Manager to something else.
Studi1
Post by Studi1 » Nov 21st, ’19, 07:18
I am new with FastKeys + do not know the rules, nor the context for changes.
I would prefer to de-activate FastKeys until I have more experience. How can I do that?
Post by Marko » Nov 21st, ’19, 12:21
You can disable the option in Preferences/General/Run FastKeys on startup.
You can also disable FastKeys temporarily - File/Pause.
You can deactivate FastKeys modules in Preferences/Module Activation.
