How to set a single start menu to present contents of all individual tabs together?
cadudesun
Post by cadudesun » Nov 8th, ’19, 13:24
I'd appreciate help.
Currently, each tab in "settings>start menu" corresponds to a different menu in "settings>tools>preferences>start menu".
I'm looking for a single menu assembly everything instead.
Thank you,
Carlos
Post by Marko » Nov 8th, ’19, 16:16
To show all items on the first menu, disable other menu settings (shortcuts and triggers) to None.
cadudesun
Post by cadudesun » Nov 8th, ’19, 18:07
It worked. Thanks 👍
