Oblomov
Post
by Oblomov » Nov 2nd, ’19, 19:12
I'm trying to use "Put Text in Quotes" from Library
SavedClip := ClipboardAll
Clipboard =
Send ^{vk43} ;Ctrl C
ClipWait 1
Tmp:=Clipboard
Tmp = "%Tmp%"
; Remove space introduced by WORD
StringReplace, Tmp, Tmp,%A_SPACE%",", All
Clipboard =
Sleep 20
Clipboard := Tmp
Send ^{vk56} ;Ctrl V
Sleep 100
Clipboard := SavedClip
However, it doesn't seem to work within the search box of OneNote, where the quotes makes it so that OneNote performs a more focused search, something I use very frequently:
Is there perhaps some way to fix this perhaps?
Post
by Tom » Nov 2nd, ’19, 19:30
Try to insert another Sleep 100 after Clipboard:=Tmp.
Oblomov
Post
by Oblomov » Nov 2nd, ’19, 21:15
Tom wrote: ↑Nov 2nd, ’19, 19:30
Didn't seem to help, unfortunately
Post
by Tom » Nov 4th, ’19, 16:42
How about this?
send, ^c
sleep 200
Send % "" clipboard ""
Oblomov
Post
by Oblomov » Nov 4th, ’19, 21:35
Tom wrote: ↑Nov 4th, ’19, 16:42
How about this?
send, ^c
sleep 200
As a standalone command? Doesn't seem to work either unfortunately :/
Oblomov
Post
by Oblomov » Nov 4th, ’19, 21:51
How about this?
send, ^c
sleep 200
Figured it out by accident
What I did was remove
From the original:
Clipboard =
ClipWait 1
Tmp:=Clipboard
Tmp = "%Tmp%"
Clipboard =
Sleep 20
Clipboard := Tmp
Sleep 100
Oblomov
Post
by Oblomov » Dec 14th, ’19, 20:17
Hm, no longer working it seems
Oblomov
Post
by Oblomov » Dec 14th, ’19, 20:23
Oblomov wrote: ↑Dec 14th, ’19, 20:17
Alright, so finally, I managed to get it working from
https://autohotkey.com/board/topic/6688 ... cted-text/
Albeit, there, it of course doesn't work either, unless edited to be exactly the following
Kind of boggles the mind, when something so... ah, who cares
Oblomov
Post
by Oblomov » Dec 24th, ’19, 14:56
Michel10 wrote: ↑Dec 24th, ’19, 07:55
Oblomov wrote: ↑Nov 2nd, ’19, 19:12
Clipboard =
ClipWait 1
Tmp:=Clipboard
Tmp = "%Tmp%"
Clipboard =
Sleep 20
Clipboard := Tmp
Sleep 100
HI, I think maybe I have a way for that, if you want
Sure! Would be interested in knowing
Currently using
Send, "
Clipboard= %Clipboard%
Send, ^v
Send, "
Which works better than the one in my last post, although doesn't get saved in the clipboard, which can probably be fixed with a quick ^a and ^c
Oblomov
Post
by Oblomov » Jan 7th, ’20, 18:40
But yeah, the aforemention command is working fine most of the time, but sometimes, it definitely triggers other macros, and royally messes up my stuff. Happens 1.5/20 times, so it's not too bad, but I use it super often, so yeah
