New user, trial version, looks like FastKeys will be just what I've been seeking for a long time.
QUESTION/PROBLEM ONE. With FastKeys enabled right-click drag-and-drop fails, in Windows Explorer. Is there a setting in FastKeys that controls this? Where?
QUESTION/PROBLEM TWO. I already use the hotkey ctrl-1 in some legacy software. With FastKeys enabled that hot key does nothing, apparently. I don't see in the FastKeys interface anywhere that controls that hotkey.
Latest version FastKeys
Win7Pro-64bit
Newbie two questions - ctrl-1 and drag-drop
ONE: you can disable Mouse Gestures module or change the default gestures key to something else - Preferences/Gestures/Gesture shortcut
TWO: change Quick add-on shortcut to something else - Preferences/General/Shortcuts
Please let me know in case of any other question.
I can confirm that right-click drag-and-drop fails in Windows Explorer. Even if there are only 2 general getures set in options.
While Settings window is open, you can't use gestures (trail appears on right-click mouse down, but doesn't disapper until you press Esc)
