FastKeys 3.12 Released
Post by Marko » Sep 3rd, ’16, 18:13
What's new in FastKeys 3.12:
September 3, 2016
- Enable/disable multiple entries from the context menu,
- Spanish common words Wordlist added, thanks Salva!
- Language translation updates, thanks sm85!
Download FastKeys HERE!
gustms
Post by gustms » Sep 3rd, ’16, 23:24
Thank you very much, Marko! Was looking forward to this.
Post by Marko » Sep 3rd, ’16, 23:39
You are welcome! :D
Gryzor
Post by Gryzor » Sep 5th, ’16, 10:03
What does the enable/disable multiple entries mean? I don't understand what it does :D
But, thanks for the continuing support!
T
PS the link in your OP is not there!
gustms
Post by gustms » Sep 5th, ’16, 13:01
Gryzor, this request: http://www.fastkeysautomation.com/forum ... tiple#p862
Gryzor
Post by Gryzor » Sep 5th, ’16, 14:24
cheers mate :)
Hlauder
Post by Hlauder » Dec 12th, ’16, 03:28
Thanks for a great update, keep up the good work! :D
